Delta wing mix on PCM10X Heli
TX
Danny -
I am attempting to setup a model memory on my 10X-Heli to fly a second Zagi, using my 8103 for the first. I am having trouble getting the mixes setup correctly. I have mixed Aileron to Elevator and Elevator to Aileron, and each control works correctly alone, but when, say, for instance the elevator is at max throw, the aileron will only deflect one surface, unlike on the 8103 where max throws of each function is 75%, and the mix drives it to 150 as needed, to ensure differential aileron movements no matter what. Setting the ATVs on the 10X to 75% will give the base deflection, but the mix will not drive it beyond that. Any ideas as to how to get the 10X mixes to either duplicat or at least get closer to the delta wing mode of the 8103?
- Tim
- Tim
Your best bet would be to set your travel adjusts to 150% if you need them to move that far, and then dial out travel through the aileron and elevator dual rate function so that it affects both sides. Doing this, you can set it up the same as the 8103 works. I hope this helps!
TX
Just wanted to let you know, that did it! Works great, and now seems so obvious that I can't beleive that I didn't think of it myself! Thanks again,
- Tim
- Tim
