6 Volt for Spektrum
QC, CANADA
6 Volt for Spektrum
I have a DX-7 and haven't yet used it at the field, but have wondered what two questions:
1. What is the benefit to going to 6v versus 4.8v? I have a mix of digital and non-digital servos (I will be keeping the digital together in one plane and the non-digital in another.)
2. How does one charge 6v batteries (I have just the standard (original/slow) Spektrum DX-7 charger.
3. How can I check to see if my batteries (4.8 or 6) have enough charge prior to a flight? I know I have to use a multi-meter but how do I actually check?
Thanks for the input!
RE: 6 Volt for Spektrum
1. Faster speed/torque for the servos. Less chance of low voltage during flight. But, a good, charged 4.8V batt should be good for most aircraft up to 90 size.
2. http://www.rcbatteryclinic.com/nova.htm or http://www.rcuniverse.com/market/item.cfm?itemId=362288 These are links to some of several programable chargers which can be very nice. You can often find good used ones on *Bay or RCU classifieds.
3. http://www3.towerhobbies.com/cgi-bin...?&I=LXEYM6&P=7 A battery checker like one of these is better that just a voltmeter. It checks the battery under a selectable load. More accurate.
QC, CANADA
Thanks Airbusdrv! So you are suggesting that I don't need to move to 6v, as I'm pretty much going to be sticking to 40 size aircraft (and will be careful to try to avoid binding with the servos.)
I particularly appreciate the links.
[8D]
[8D]
6V is not required, either 4.8V or 6V will work fine. You do however need to make sure that the battery pack size (mah) and type is adequate for the model.
