delta wing setup
KS
delta wing setup
ok rookie question about delta wing set
i have a bug indoor flying wing it has a rudder - and what i would call elevons - elevators and alerions combined
i have the radio set up with the delta wing setup and the elevators work ok and the alerions work on but when i input the control of
up or down elevator and or right or left alerion only one of the controls moves and the other goes to neutral and i do not think this is correct can you tell me if i need to change the setup
thanks tg
thanks tg
RE: delta wing setup
Do you mean that when you have say full up elevator and you move aileron that only one side is moving? If so that is normal as the servo on one side will run out of travel. It will still have effect in flight however.
