Best way to set up dual rudder servos without a "Y" with a 10x?
My Feedback: (33)
FL
I'll like to know how I should set up dual tandem rudder servos without a y harness.
I know I have to mix Rudder with an aux. ,Which one and how do I inh. the switch or knob of that aux, and also how do I get that aux. slave to work with the trims, DR , expo and snap switches .
thanks.
epc.
thanks.
epc.
The Aux 2 channel is usually open. You can do this mix by setting up a rudder to aux 2 mix, press page twice, press SEL under the TRIM option and this should now say ON. Now press page once, and set the rates to +100% in both directions of rudder.
