JR 9303 2.4 Dual Channel Problem
CA
I have hit a snag programming my new 9303: IMAC plane, acro mode, flaperons for wing type, all switches "INH" in device select. I can select a 2nd channel for elevator in Wing Type (I used Gear) but I cannot get a second channel for ailerons. When iIclick on the INH on the MATE line for ailerons, I don't get any menu. (I want to use the flap channel for my second aileron). I have set up flight mode with AUX2 for my FM switch.Trim is on COM, D/R is on FM, Flap trim is OFF. I must have overlooked something but I can't find it . Any help appreciated. Thanks,
Mike Worthen
Mike Worthen
RE: JR 9303 2.4 Dual Channel Problem
When Flapperon mode is enabled it turns off the mate function for the aileron channel.
If you look at the Travel Adjust or Reversing menus you will see that the left aileron (aux1) is already named LAIL and you are already "Mated"
Its a done deal.
Troy Newman
Team JR
Its a done deal.
Troy Newman
Team JR
CA
Dear Troy,
Thank you very much. I thought it was something simple. I will get on with programming my plane. Cheers,
Mike
Mike
