R610M and R610UL broken antenna
I picked up two M's and one UL from someone recently. He has clipped the antenna wires down to 3-4 inches and had attached deans antenna's or some other micro antenna. I would like to return these to their original length. I see that horizon sells receiver antenna wire. Is this wire already at the correct length? Do I just need to solder the replacement length on or should I send these in to have this done?bt
