XF421ex No Power
XF421ex No Power
Hi Danny,
I have an XF421ex. I removed the battery to cycle it on an AccuCyle Plus and everything appears to have worked ok. The voltage discharge & charge times are correct. My problem is, upon re-connecting the batter to the TX and turning the TX on, I don't get any LCD display. I have 11.2 volts at the connector. Any thing else I should check?
Thanks in advance,
AL
Thanks in advance,
AL
XF421ex No Power
If nothing is happening it may be a blown fuse, or it may be something more serious. The fuse is behind the back half of the case in between where the crystal plugs in and where the battery goes. This fuse is a 3 amp, 250 volt, fast acting fuse. If the problem is not the fuse, you will need to send in your system for service.
