Brake with snap roll button
In that case, yes you can. To set this up select the channel that you want the brakes to be on. I've set this up on channel 8, but you can select any that you have open. Begin by going to code 17 and activating the channel that you have selected. Then go to an open program mix, and set up a mix of the channel to itself. Press page one time, and press SEL under SNP. Now press page twice to get to the main mix screen. Slide the aux 3 slider all the way or the switch, dial, or lever you are using that controls that channel, one way or the other. Either way should work fine. Then press STORE to enter an offset. Then go back to code 17 and inhibit the channel that you are using. Then return to the program mix that you have set up. Then enter in the percentage needed. You can set the percentage to -100% with the switch off to +100% with the switch on or further and get more travel. You can adjust the percentages to get the amount of throw needed with the switch pressed and not pressed. If you have any difficulty setting this up please feel free to give one of our techs a call at 877-504-0233.
