Help
Help
Hi Dan
I have an 8103,old heli transmitter.Today I tried to use flaps on fixed wing.I used pitch trim and aux 2,discovered I needed to reverse one of the servos and added a precision electronics Y with reverser.now they both go the same way but one then the other and I am not sharp enough on the aileron trim for that.How do I fix this.I have already used gear switch to pull up a water rudder.
Thanks Gregg
Thanks Gregg
Help
I believe that you can set up the flaps like this. If you need to reverse the flaps then, you can either reverse the channel needed or reverse the mix percentages from + to - or vice versa. If you have any further questions please feel free to give one of our techs a call at 877-504-0233. http://www.rcuniverse.com/showthread...53&forumid=174]
