Dual elevator mixing
RE: Dual elevator mixing
As long as Ch7 is available, you should be able to mix that with Ch3. You are not going to use Ch5, either, unless you use that as a Kill Switch. You will probably be mixing Ch 2 and Ch6, for Ailerons, using the Flapperon program. The last plane I used my 8103 on was a Quique 72" Yak54 with an OS160.
My Feedback: (89)
[8D]Go to Mix#1 Master: Gear Slave: Gear, Set the Rate at -100% -100%(may require flipping the gear switch), This will Inhibt the Retract Switch.
Go to Mix#6 Master: Elevator Slave: Gear, Set the Rate at +100% +100%(May require moving the elevator stick), This will allow the Trim to move both halves..
Good Luck
Codimata
AMA 11269
Good Luck
Codimata
AMA 11269
