Update PCM9x DSX10 when?
Has anyone heard any rumours about a new JR radio to compete with the Futaba 10C. I am using my PCM 9X2 with a Spektrum module . I would like an integrated 2.4ghz set , with a working gyro menu. I am continuing to use my pcm9x hoping that an update will come. but I may got to the Futaba 10C, It looks great for heli use. This may not be so bad before I get too many 2.4Ghz receivers
RE: Update PCM9x DSX10 when?
G'day Mate,
JR already have a DSX9 out, it has been out for over a year, full DSM2, has Heli, Acro & Glider modes. Check out MacGregors web site, in the UK.
Hi I realise that the dsx9 has been out for over a year.
What I was asking is , will there be a new version of the 10 x, with the nice bits of the Futaba 10 c like a working gyro menu and more advanced software rather than just a new number and module in an old friend like the PCM9X2 rebadged.
My point is that the PCM9X2 has been around quite a while now (9303) in the USA and is there to be a new model to replace it, not just the same radio with a 2.4 module built in. JR didn't even make a new instruction book. If you buy a DSX9 in the UK you get a PCM9X manual with a dsx9 addendum. Plus the fact that it is also very expensive!
What would everyone else like to see.
I would like a similar radio to the Futaba 10c but JR,
Working gyro menu, back lit low latency ability to bind with Spektrum receivers wopuld this be the DSX10?
cheers
D
cheers
D
What about the JR12X?
One thing I don't like about the Futaba 10C is that it only has 8 proportional channels. The Futaba 9CAP only had 8 proportional channels. After I bought a JR XP9303, I sold my Futaba 9CAP. Flaps on a Switch, 9 Proportional Channels, Flight Modes, Spektrum Module that supports 9 channels, 9 channel PPM Rx if you did not want to purchase the more expensive 9 channel PCM Rx.
The X9303 is not backwardly compatible with 72mhz, but it has Model Match.
I am not a Heli guy so I do not know much about the type of programming features that would benefit Heli fliers.
