Jr-8103
Jr-8103
I get an Error when I turn on the Xmiter and I loose all of my plane's stored info. I re-program all setting and loose them again when I turn of the xmiter for 24 hours. Any Ideas??
Jr-8103
It sounds as if the lithium battery is drained and needs to be replaced. You will need to send it in for service. The charge for lithium battery change and a check over of the system is generally in the $40 to $50 range. You can fill out this form to help provide as much information about the problem as possible.
http://horizon.hobbyshopnow.com/medi...rchecklist.pdf
