JR to Spektrum
RE: JR to Spektrum
The DX5i manual says the following;
Trainer
The DX6i offers a Trainer function that allows the transmitter to operate as a master or slave. The trainer switch is
located on the back left of the transmitter.
MASTER
The transmitter can be used as a master but the slave transmitter must have the same programming (i.e. reverse,
travel adjust, dual rates, mixes, sub trims, etc.) as the master.
SLAVE MODE (CONVENTIONAL)
When using the transmitter as a slave with another DX6i it’s necessary to match all the programmable settings (i.e.
reverse, travel adjust, etc.).
The SX600 manual just says Plug them Together.
Just make sure the SX600 does not have the Power Switch turned on after you plug them together. If it still does not work, call Horizon. I do not have these two Tx's in front of me to test this out.
Trainer
MASTER
