does anyone know if this module will fit my 9303
My Feedback: (61)
i was thinking about upgrading my 72 mz 9303 to 2.4 however i hate the loose wire running from the mod to th antenna . i happen to run across this 2.4 mod that was for the 12x i'm not sure if it will interchange or not. thanks WB_1
ID
RE: does anyone know if this module will fit my 9303
I've done this mod...it is not difficult and it elliminates the external wire....limits your ability to change from a 2.4 module to a 72mhz module though...
http://www.rcgroups.com/forums/showthread.php?t=687382
Randy
Randy
Warbird,
What you have pictured is the 2.4 GHz module for the 12X MV. While anything may be possible, to make this module work with the 9303 is about as impossible as it gets. The MV has not one but two 14-pin connectors that are located on different spots than the one on the 9303. Your first task will be to find out what all those pins do.
Randy's mod is one practical alternative. Be aware that only the modular 2.4 GHz JR transmitter that has model match and servo sync that is on the integrated transmitter is the 12X MV.
Allan
Allan
