DX6i Question
DX6i Question
When setting dual rates on my DX6i the elevator indicator does not change from high to low rate when I move the switch from 0 to 1. It displays 0 in either switch position. Am I doing something wrong? I am using an AR6100 receiver.
swimmer
swimmer
RE: DX6i Question
You can set different high / low settings depending on where the control stick is at the time of setting. When you see no setting adjustment....are you moving the stick up or down...? Rich
RE: DX6i Question
Try MOVING the stick up....then set your UP value...then MOVE the stick down..set the down value....then, when you switch to high/low rates, watch the value change when you move the stick up or down. Hope this is clear. Rich
RE: DX6i Question
richg99,
Thanks and I'll give your suggestion a try after work today and let you know. Funny though, this is Model 5 on my DX6i and no issue like this with the other four.
swimmer
swimmer
