9303 - split elevator- trim function?
I have a 9303-2.4g. and I have 2 servos operating one half of the elevator each.
The elevator operates correctly -(both halves together)- but I only have manual tx. trim
on the righthalf - which is plugged into the elev. channel on a JR. 921 rx.
The left half is plugged into aux.-2. No trim on this side.
Can anyone help?
Graham
Can anyone help?
Graham
My Feedback: (89)
RE: 9303 - split elevator- trim function?
Try this setup: The mate function
Hook up 2 Servo Elevator
#1. Go to DEVICE SELECT and rotate the roller until you are under AUX3 (on the bottom of the screen), Press the roller and INH AUX3
#2. Go to WING TYPE: NORMAL and rotate the roller until you are under ELEV, Press the roller and select AUX3.
NOTE: You may have to REVERSE AUX3 or both depends on the hookup of the linkage.
NOTE: For the Elevators Right Elevator to Elevator and Left Elevator to Aux3.
