XP8103....Help!
XP8103....Help!
HELP! ca ayone help me set up mt xp8103 radio? I have never used this type of radio before and I am really in over my head.I have the reciever,servo,and battery pack all set up. but the throtttle wont work, I dont have anything else hooked up just the throttle. I understand that I need to programthe radio any help would be appreciated thanks in advance Tim
TX
RE: XP8103....Help!
First, get thee to:
http://www.horizonhobby.com/Products...odId=JRP8612**
and get the manual if you don't have it . . . .
Then, take the time to actually *read* the manual. Love the manual. *BE* the manual!!!!
Most likely, you are missing something simple, such as the detail that throttle on a JR rig is channel 1, not 3 like Futaba and HiTec.
If the manual doesn't get you where you need to go, come back and ask a specific question. What you posted above gives us no information to go on whatsoever, other than to refer you to the correct manual for your radio . . . .
- Tim
- Tim
RE: XP8103....Help!
ok I am printing off the manual. the reciever is a pcm10 Ner-910xz. I have a batterypack plugged into the switch harness and the other end plugged into the reciever.if I turn everything on the servo move a little bit like all of them do and thats it. no response from the transmitter.I remember when the airtronics vanguard was a big deal.thanks guys Tim
RE: XP8103....Help!
Having the correct modulation is very important. If you have a Non-PCM Rx or you are using your Tx with a Flight Simulator, you need PPM Modulation. If you are using a PCM Rx, then you need to set the Modulation, on that Model Memory, to the correct version of PCM. When you have the correct Modulation and the correct channel. you should be communicating. This is true for Hitec, Futaba, Airtronics, etc.
If you buy a 2.4 module, you also need to set the modulation to PPM.
If you switch to a dedicated 2.4 Tx, you won't have to worry about modulation.
