Exploded View DX6i
Exploded View DX6i
I have a DX6i which does not have an ratchet device on the trim ... I have a small medal strip in the styro box packing the Tx was in and I think this is what I need. However I cannot find a reference to this piece in the manual nor can I find a reference to a racheting device. Is there an exploded view of this TX showing parts available?
Leo
Leo
RE: Exploded View DX6i
Leo,
The manual doesn't specifically mention the throttle ratchet, but if you will look at the illustration on the bottom of page twelve you will see a good picture of the TX with the rear case removed. See that bright metal strip on the right side of the picture with the white arrow pointing at it. That is what you are looking for.Black screw at the top white screw at the bottom. You should be able to get it from there.
Good luck,
Oscar
Good luck,
Oscar
