DX7 Programming flaps & ailerons
I had a quick look on other posts for this query but can't find an answer.
The problem I have is that when I operate the flaps the ailerons work as well.
Setup
The two flap servos are connexted to the AUX2 channel via a Y harness
The left aileron servo is connected to the AUX1 channel, the right aileron servo to the AIL channel and FLAPERON is activated in the menu
AUX2 is set to the 3 position switch and FLAPS is set to SYSTEM.
The ailerons operate correctly when moving the stick from left to right but when the 3 postion switch (mode switch) is activated the flaps deflect (both down) but so do the ailerons (one up and one down I think). I can get everything to work correctly but only by setting FLAP to INH in the setup menu but then this doesn't allow for the adding of elevator deflection down as the flaps are applied as you can do with FLAP set to SYSTEM.
Is there a conflict that prevents the flaperon function being used with the flap system or am I doing something wrong.
Thanks in advance and cheers
David
Setup
David
My Feedback: (89)
RE: DX7 Programming flaps & ailerons
[8D]Try this:
DX7 DUAL AILERONS AND DUAL FLAPS
1. Go to the Set-up mode (Hold down Scroll and Select keys while turning on)
2. Scroll to the Input Select screen
3. Set AUX#2 to INH, AUX#2 Trim to INH, Flap to System(should be default), Flap trim to INH,
This turns off AUX#2 channel from the lever
4. Do not activate Flaperons. It must be OFF
Aileron Setup
1. Power off the TX and turn on. Go to normal
programming
2. Scroll to Pmix #6. Set Aileron as master and
AUX#2 as slave. Set mix levels at 100%
(This requires movement of the Aileron Stick)
3. Set the Sub trims on the aileron and aux#2 to
match each other.
5. Scroll to Travel Adjust and set the desired
Travel for the right aileron and left aileron
(AUX#2)
6. If the ailerons are backward..go the reverse
Switches and correct
Flap Setup
1. Scroll to Pmix #5. Set Aux#1(Flap) as master
And Gear as slave. Set the mix levels at 100%
(This requires flipping of the gear switch)
2. Scroll to Pmix#1. Set Gear to Master and Gear
To Slave. Set mix levels to –100% -100% (This
May require flipping of the Gear Switch)
This will inhbit the gear switch.
3. Set Sub trims on the Aux#1 (Flap) & Gear (Left
Flap) to match each other
4. Scroll to travel adjust and set 100% on Aux#1
And Gear.
5. Scroll to FLP SYS screen, Set the desired
Travel for each of the switch settings.
You can also set any elevator compensation.
Set Right Flap to Aux#1, Left Flap to Gear
Aileron Setup
programming
match each other.
(AUX#2)
Flap Setup
And Gear.
