PCM10 with 2.4ghz module conversion
I bought a 2.4 ghz Spektrum modlue to convert my old PCM10 to 2.4. Problem is that with the 2.4 ghz module installed the Tx voltage is unstable and lower than with the 72mhz module. Horizon said don't worry be happy, I am not nor do I trust using this setup with unstable voltage being displayed on screen.
Help
Roy
Help
Roy
OH
RE: PCM10 with 2.4ghz module conversion
