10x heli mixing question
RE: 10x heli mixing question
before i got a 12x i used my heli version 10x for everything i flew, even my turbine jets. what you'll have to do is mix two channels for aileron use, then use the pitch curve for flaps (take off flap is normal flight mode with 0-0-0 on the curve, stunt 1 is take off flap with say 40-40-40 on the curve, stunt 2 would be landing flap and 75-75-75 you're actual numbers will differ) and mix pitch to the ailerons channel and then a negative mix of pitch to the slaved aileron channel. you'll find that you use up allot of your mixes but there isn't much you can't do with the heli version, i did have Horizon mod my Aux4 and Aux5 pots for a more turbine friendly setup.
