How to convert JVC, Canon, Panasonic Camcorder MOD video on Mac?
How to converter JVC, Canon, Panasonic camcorder Mod video to FLV, MP4, MKV, AVI, 3GP, etc all popular formats on Mac
The MOD video format is encoded by using MPEG-2 video codec with AC3 audio codec. It is mainly used for standard definition video which is used by Canon, JVC, Panasonic, such as: Canon FS100, FS10 and FS11,JVC GZ-HD3 GZ-MG130, GZ-MS100U, Panasonic SDR-S150, SDR-H20, SDR-SW20, SDR-S26,and so on. Besides, MOD video can be viewed on a computer with a player that is capable of reproducing MPEG-2 video. This video can be easily authored for watching on a DVD player without recompression, because it is fully compliant with DVD-video standard. Even more, if you just wantto playback Mod video files in VLC or QuickTime on Mac, you only need to rename them as .MPG or .MV2. Butif you want to play on the iPod, iPhone, Apple TV, PSP, Zune, CreativeZen etc, or want to edit on Final Cut Pro, iMovie and most other Macvideo editors directly, it is impossible to achieve that.
So the follow solution may help you out of trouble.
First: Convert Mod video to MP4, M4V, 3GP, AVI, WMA, MOV, etc that is understandable by your media devices or what you want to get.
Second: Convert Mod video to MOV, DV, etc which can be edited fluently in your Final Cut Pro, iMovie, etc.
Third: Convert Mod files to FLV could be uploaded on Youtube, or to any other popular formats like AVI, MKV, ASF, DivX, XviD, VOB, RM, RMVB, FLAC, MKA, OGG, WAV, AC3, etc to your media player could be recognized.
All these converting works can be accomplished by using Moyea Mod Video Converter for Mac, for which is a professional tool to convert Mod video files to almostall popular formats. Please pay your attention to the operation; you will not be annoyed any more.
Step1. Download and install the program, then will pop up a comfortable interface.
Step2. Add Mod file.
Click the Add button; please select the Mod video you want to convert.
Step3. Set output file and advanced setting.
It is an important step, just in this step you can select the format you want. Please click drop-down list of the “format” to choose one. Then according to your own will, you can click the “Settings”to adjust Video Codec, Bit Rate, Video Size, Frame Rate, and Aspect Ratio of video as well as Audio Codec, Bit Rate, Sample Rate, Channels, and Volumeof audio to get better effect of your output video.
Step4. Set destination file.
Click “Browse” to load the output files where you want to save.
Step5. Convert video.
After the setup, now go to start conversion. Click “Convert”button, you could see an interface be capable to check the convertingprocess, confirm the time elapse, time left, estimated size. And sometimes you want to have a rest, please choose shut down computerafter conversion.
Now all the troubles have been disappeared after doing this. However, before conversion, you want to edit the video/audio or addwatermark on your video. Please read the follow optional choices. First of all, please chick “Editor” button.
1. Trim video.It is used for select the wanted clips for converting, for maybe you don’t want so large size or the whole footage. So click “trim” to cut.
2. Crop video.
This function could be usedfrequently, because most of us don’t like watch some videos which haveblack sides. So choose this function and click “Crop”, you can enjoy them in widescreen.
3. Add watermark.
Do you like to add text in your self-made video for describing? Please choose “Text watermark”.Do you like to add logo in your video for protecting your copyright oradd video for playing two videos in sync? Please click “Image/video watermark”.
Now hope all of you enjoy the happiness with this converter brings to you.
Your tips are very helpful, I used the MOD converter to convert my Canon FS300 MOD to Asus EEE Pad Slider easily, it does work. However, I get another better solution, it cannot only convert MOD files, but can also convert 1080P AVCHD, MXF, videos to common formats like avi, mp4, mov, flv, wmv, and so on. It can remain the original video quality and lose zero quality while the conversion, In addition, now the MOD converter can add watermark(image and text), add 3D effects to video, and download videos from more than 100 websites, If you have any videos need to convert, you can rely on this MOD Converter.
For more details, refer: http://www.iorgsoft.com/
