X9303 twin engine
My Feedback: (8)
X9303 twin engine
I can't seem to make both engines operate the same. The left engine is plugged in to Aux 4 and slaved to Thr but I can only get the trim to move the left thr a tiny amount. Works ok for the R Thr. Throttle curves are adjusted the same. Any help out there?
RE: X9303 twin engine
I can’t duplicate your problem. If you slave AUX4 to THRO with a linear mix, the trim works both throttles. A better way is to use the engine dual/mate in the Wing TYPE menu and mate the throttle to AUX3. That way you have the option of using the AUX TRIM as a separate trim for the throttle on the AUX3 channel. How are you slaving AUX4 to the throttle?
Allan
With the curve mix I see your problem. There may be a solution by playing with the travel adjustments and subtrims for the THRO and AUX4. A simpler solution would be to put the left engine on some channel other than AUX4 by means of Wing Type menu dual/mate. When you do that you will get four throttle curves. One for each engine for each of the two select positions. I don’t fly twin engines but I would think with individual throttle curves for each engine you will be able to match the rpm’s.
Allan
ORIGINAL: codimasta
Trim function only works on Mix #5 & 6
Allan
