JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Connecting Servos to AR91000 Receiver
Reply
Old 01-01-2010, 02:32 AM
Rockyaged
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Connecting Servos to AR91000 Receiver
I am a long time JR user and just got a Spektrum DX7, which is manufactured
by JR. I was expecting all connections to be made the same. I am using Hi-Tech
Servos and 3 JR Match Boxes. When attaching the servo connector to the AR9100
Receiver, the signal wires (Orange JR, Yellow HiTech) are on the bottom versus
being on top in the JR Receivers. Close looking shows the connectors and slots in
the receiver to be keyed. Yet I am not comfortable about this and would like some
comformation that the Negative servo wires do indeed go on top.
Gerald
Rockyaged is offline
Old 01-01-2010, 08:31 AM
BuschBarber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Connecting Servos to AR91000 Receiver
Spektrum and JR use the same Color Code for the wires and they plug in the same way. The only thing I have noticed about Spektrum Rx's is that the ports where the servos plug in are a slight bit smaller and the servo connectors have to be plugged in perfectly straight in order to get them in. You also have to push with a little more vigor.
I just looked at two of my Rx's.
In the case of my AR6100, the Black wire is towards the closer end of the Rx case.This is the AR6100 with the pins coming out of the top of the Rx case.
In the case of my AR9000, the Black wire is towards the bottom.
The shape of the connector forces you to plug in the connectors only one way.
BuschBarber is offline
Old 01-01-2010, 10:03 AM
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Plug one in, if it works its correct, if it doens't it just wont work but it won't hurt anything.
BarracudaHockey is offline
Old 01-01-2010, 10:10 AM
Zeeb
Zeeb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah it seems to me that there's not a lot of commonality in the plug orientation with the Spektrum/JR rx's and the slots are tight as Rich mentioned. On mine, I've started trimming the two corners on the servo plug wires so they'll go into the slots better. I started doing that when I still had a few Futaba servos with the tab, trim it off and things were still pretty tight so I started trimming the corners as well.
The Hitec servos don't seem to fit as tight so maybe their connectors are a bit smaller, but on my R921's I still trim the connectors to fit the small angles on the servo slots. I haven't used either my AR-9100 or the R-1222 yet but suspect they'll be the same as the R921's.
All the rx's are marked somewhere on the case with the correct orientation of the servo wires so just verify that you're getting that right and you'll be fine.
Zeeb is offline
Old 01-01-2010, 04:09 PM
FrankFuss
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With both my Spektum AR9100 and JR R921, the servo connector orientation is the same, signal wire to the bottom. Trust in the key Luke.
FrankFuss is offline
Old 01-31-2010, 12:38 PM
skorman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On my JR R921 the servos plug in opposite of the way they plug in to the Spektrum 7000. If you look on the label of the receiver, it shows the positive and negative orientation of the servo lead.
skorman is offline
Reply
Display Modes
