Binding question for the 6200 series rec?
WI
Hi;Just bought couple of these and find when Itry to bind get no lite on the little one one,big one lites and it seems to bind OK but no lite on little one??Radio functions OK but thought should get lite on both of them??Haven't tried flying yet with it or range checked it!Thanks
NE
RE: Binding question for the 6200 series rec?
Yes, you should have the indicator light appear on the satellite, as well.
Check the wires at the plugs, for one.
But, do not fly, until you have a properly working Rx system.
It's best to be safe than sorry.
HTH,
EJ
HTH,
EJ
WI
HI;Thanks kind of figured that!It is new out of the box so guess can try another new one I have with that receiver see if it works.I beleive could just plug in the othere satellite one see if it will work with this receiver?Horizon is good about warrenty so suppose should just send it back to them!Thanks!
