AR500 receiver question
FL
Hello,
Is the Spektrum AR500 5 channel reciever made for glow powered planes.
What is the range on this receiver, could I use it in any size aircraft up to about 80" wing span.
RE: AR500 receiver question
AR500 is a full range, 5 channel receiver. It actually has 6 outputs, two are for ailerons. That eliminates the need for a 'Y' adaptor if you use two aileron servos. You can use it in either glow or electric. Enjoy.
