AR6110e range in feet
NY
RE: AR6110e range in feet
Spektrum calls it a park flyer Rx , not a full range Rx. Ido not know what actual feet number they would tell you but you could go to the Spekrum site and check. I can tell you Ihave flown it in 2-3 pound EP models out to distances that are the limit of seeing the model clearly. Based on our field size Iwould say Ihave flown it to 600 at least with no problems. The conditions at you field may not be the same.
If you really intend to go with larger models or greater distances spend the extra $20 or so and get a full range Rx. Better safe than sorry.
I'm not sure of the range of the AR6110E, but I lost my PZ Corsair at 900 feet distance with an AR6100E. Spektrum suggested a maximum 700 feet for the 6100E.
