8103
My Feedback: (9)
TX
What's the difference between an 8103 Aircraft and an 8103 Heli system? I want to purchase an 8103 but I need to know if I can use the same transmitter for both aircraft and helicopters. Is the only difference the way the systems are configured, i.e. servos, receiver?
Thanks, Tom
Thanks, Tom
The only differences between the two systems are the equipment included, some labels, and switch positions. Each system has the switch positions optimized for each style of flying. The programming in both systems however are identical. I would recommend getting the type of transmtiter to match the type of model you fly the most. If you fly helis mainly, get the heli 8103, or vice versa.
