Servos not moving.
Servos not moving.
New AR7000 RX. Sometimes when switching on the system, everything seems to initialise correctly (all lights solid after a couple of seconds) but absolutely no movement fron the servos when the sticks are moved. Recycling the power to the RX seems to correct the issue. Probably only happened four times in two or three dozen switch - ons. System works ok otherwise, but still a bit worrying. Any ideas please?
C8
C8
RE: Servos not moving.
Thanks for the reply. I think you may be onto something, as I had the helicopter in my garage next to the closed metal door and underneath some aluminium ladders hanging from the roof. Also had the tranny on the bench next to the model.
C8
C8
