Radio incompatible with fingers
Just started flying RC. Flown 1:1 for years, but this is something I can afford. Got a plane and flew it but I'm a lefty and found using my right thumb to be frustrating. I can compensate, but it will never be the same as flying goofy. Is there a way I can hack my DX5e into a mode 3 or at the least BUY a mode 3 DX5e? I'm not financially secure:eek:, so saving bucks is a huge deal for me.
RE: Radio incompatible with fingers
Your brain will overcome.Trust me. You will be better off in the long run staying with Mode2.
Being a full scale pilot your brain should immediately grasp having ail-ele on the same stick regardless of what side it is on.Im guessing you didnt spend much time flying from the right seat? Its kind of the same as a conventional forward back seating.Right hand on stick left on throttle and feet on the pedals.Im also a lefty.Ive done alot of flying from the right seat and alot of conventional.It just clicked right away. The other thing is that if you ever fly anything else the chances are 99.some% that it will be Mode2.You will be really screwed if you adjust your brain to something non standard and then try to use something else. |
As a right hander, I feel it would be almost impossible for me to control a model with my left hand (pitch and roll). Maybe it was years of full size soaring. Anyway I would consider mode change. HitecAurora, Spektrum dx8 and as I understand it many other modern transmitters.
Coyt
I guess I just assumed but do you actually have a Mode 2? That would be ail-ele on the right stick and thr-rud on the left. That would be the standard in North America.99+% will be Mode 2. |
I like to kid my German friends who fly Mode 1. I tell them, "Mode 2 is good enough for the F-16 pilots defending your country. :D"
Andy |
ORIGINAL: AndyKunz I like to kid my German friends who fly Mode 1. I tell them, ''Mode 2 is good enough for the F-16 pilots defending your country. :D'' Andy To clear something up: Your brain will overcome.Trust me. You will be better off in the long run staying with Mode2. Being a full scale pilot your brain should immediately grasp having ail-ele on the same stick regardless of what side it is on.Im guessing you didnt spend much time flying from the right seat? Its kind of the same as a conventional forward back seating.Right hand on stick left on throttle and feet on the pedals.Im also a lefty.Ive done alot of flying from the right seat and alot of conventional.It just clicked right away. The other thing is that if you ever fly anything else the chances are 99.some% that it will be Mode2.You will be really screwed if you adjust your brain to something non standard and then try to use something else. Thanks for the inputs, guys. -C |
NEWS! This guy on another thread I posted (same topic) says this:
G'day Mate, You should be able to fix your TX to work mode 3, it is only reverse mode 1, so you have to start with mode 1, so rudder & throttle is on right stick, ailerons & elevators on left stick, is that what you need? if so just plug rudder into aileron slot & aileron into rudder slot on the Receiver. Easy fixed. |
That should work fine on a non computer radio.I guess in your situation it would be prudent to go with whatever mode works for you.
As you move forward it will be a simple process with a DX7s or above.Simple mode changes from 1-4. |
Okay well I'll give it a whack and see if it flies. *crosses fingers*
You might also consider the "thumb and finger" pinch technique. Some folks feel it gives more accurate movement and feed back.
