RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   JR Radio & Spektrum Radios (http://www.rcuniverse.com/forum/jr-radio-spektrum-radios-116/)
-   -   Can I use digital and analog servos on same Rx? (http://www.rcuniverse.com/forum/jr-radio-spektrum-radios-116/11358194-can-i-use-digital-analog-servos-same-rx.html)
Kmot 01-05-2013 10:22 PM
I will be setting up a new model, and will be using five Spektrum A6020 digital servos for flight control surfaces. I would like to be able to use one of my 'regular' cheap servos for the throttle, and it is analog.
Is that OK to do?
My Rx is a AR8000 and I will also be utilizing the TM1000 telemetry module.
Thanks.
alan0899 01-05-2013 11:09 PM
RE: Can I use digital and analog servos on same Rx?
G'day Tom,
No problem, as long as the analogue servo can handle the battery voltage that you are using,
some analogue servos can't handle 6 volts, as in JR ES539's.
That is the only stipulation.
I do it all the time, without a problem.
Cheers.
Kmot 01-06-2013 12:22 PM
Thank you Allan!
kevenoco 01-06-2013 04:07 PM
I use a JR analog throttle servo the rest are digital with no problems on low frame rate (22ms) with my DX8. I was told by Horizon Hobby tech support to use the lower frame rate unless all servos are digital. I don't really understand the reason and I am skeptical about it but it's not worth the risk for me. I cannot notice the difference between low and high frame rate (22 vs 11ms)
The manual says "...fast frame rate is not compatable with some types of analog servos."
I would be very interested to hear an expert chime in on this.
dirtybird 01-06-2013 04:32 PM
An analog servo sends a pulse to the servo each time the frame updates. If you double the frame rate you double the pulses that go to the motor. If the servo is heavily loaded it might burn out the servo. For a servo used on the throttle it has very little load so it should be able to handle it if it is not stalled.
A digital servo makes its own motor pulses independent of the frame rate.
Kmot 01-06-2013 04:33 PM
Thanks for that info. I have a DX7s. I will have to look up the default frame rate.
BarracudaHockey 01-07-2013 07:08 AM
22ms is default
Only the primary servos (ail, elev, rudder and pitch in heli mode) get the increased frame rate if I recall correctly.
