Need switch ID stickers for DX6i
Completed a mode change, but HH can't furnish new sticker for properly naming the new switch positions. Can anyone help, or tell me how to remove the stock sticker without messing them up? I wonder if judicially applying heat would work?
Ideas, anyone? Bill |
Cover the stock stickers with opaque tape?
Then write on the opaque tape, or another layer of clear tape. I never look at the labels anyway! (Just use the same switch and it's function on all planes.0 |
Hi Chuck:
The stickers are for the purpose of keeping the transmitter in the original factory configuration. I can use it without any stickers, but the next guy may not be able to. Thanks for your suggestion. Bill |
Was it mode two you converted from? If so, just put it back before selling it as that's the most popular in the USA.
Originally Posted by Bill Fleming
(Post 12085129)
Hi Chuck:
The stickers are for the purpose of keeping the transmitter in the original factory configuration. I can use it without any stickers, but the next guy may not be able to. Thanks for your suggestion. Bill Well, you will need to change the mode back if you want to sell it in the original configuration. What's wrong with the original factory stickers? |
Hi Chuck:
Your idea is valid but assuming the original can't be removed without damaging them, your suggestion might not work. Also, I would not have either replacement mode one or two stickers. Thanks for responding Bill |
