DX6 Park Flyer radio question
Are the Channel 5+6 2 position toggles on top of the transmitter bidirectional? Or just on/off?
The Manual shows Ch 5+6 with servo's plugged into them... Like, the 'Gear' toggle runs the landing gear up and down, right? (bidirectional) So, can I plug in an ESC into the 'Gear' toggle channel to run a dump body screw drive up and down? The screw drive has limit switches at end travel, so it just needs to be reversible. Thanks for any help with this! |
There are several versions of the DX-6 tx, you'll need to specify which one it is?
Like it says in the title, it's the DX6 Park Flyer version (the original one) DSM only.
Nothing??
