8411's, 8511's and 8611's on li-on regulator
Hi,
Am just about to buy a fromeco li-on setup and just wondored if this was ok for these servos. I just was checking as in leaflet you get with the servos it says dont use with 6 volt systems. The regulator will be 5.5v so should be ok but confirmation of this will be appriciated. regards Matt |
RE: 8411's, 8511's and 8611's on li-on regulator
For US JR equipment, that set up should work just fine. I'm not sure on overseas equipment. You would need to contact MacGregor for further information.
