datasafe
Danny , I am unable to receive two models in transfer to my pc I get error code - run time error 53 file not found Thanks Bob
datasafe
Do all other models in the TX download fine to the datasafe?
datasafe
Yes I have 6 other models downloaded Bob
datasafe
That is an odd problem that I have seen happen a couple times and I'm not real sure what the reason is. I'll do some experimenting here and see what I can find, and I'll let you know.
datasafe
Danny did you ever come up with a answer to my datasafe problem? Bob
datasafe
One thing that I have seen a few times lately, this may or may not be the problem you are having, is sometimes the ECU in the TX causes it to only transmit some models, I have seen this a couple times lately. Unfortunately the fix for this requires the loss of memory in the TX. You can send in your TX and we can check this out if you would like. Other times I have found that one computer all models will work fine through datasafe, and other computers 1 or 2 models won't work. For this I haven't been able to locate any trends as to what is causing it.
datasafe
I will send it in thanks Danny. Bob
