Trainers ?
Can I connect a JR 'Super Max 66' to a JR XP8103 as Master/Trainer ? I want the Max 66 to be the master and the XP 8103 to be the trainer. I noticed the Max 66 does not have the Momentary toggle switches that the XP8103 does. The switches that allows you to swap between master and trainer controlling the plane. If this is possible how do I do it ?
thx |
Trainers ?
I believe the max 66 is the same TX as our 622 in the states, if this is the case, there should be a push button next to the elevator dual rate switch on the front of the TX that is used for the trainer system. You should be able to do that.
Button ??
The Max 66 seems to be minus the button. Unless I am going crazy. http://www.iroquois.free-online.co.uk/max66.htm Here is a site with a front pic of the Max 66. Exactly where is this trainer button ? Maybe that is why JR has two differnent model Numbers seemingly for the same bit of gear.
Trainers ?
I do not see that it has the same button. You may want to give O'Reilly a call at 61-8-8351-0544 and see if they can provide you with more information.
Trainers ?
Thanks for the response dsnyder.
