Century VII FM Trans.
Danny,
I have a Century VII FM(2 stick Heli) transmitter that I am having a problem with. There is a black wire coming off the ON-Off switch circuit board that has come loose from the other connection. The problem is, I can't tell where it was connected. Is there anyway to get a wiring schematic for these transmitters? The black wire in question is larger than the other wires in the circuitry and is still attached to the switch circuit board. Thanks for any assistance. Rick |
I don't have a schematic that I can send. It sounds like the ground wire, it goes to the silver box that the module plugs into, there should be a tab with solder on it. That should be it. Let us know if you have any further problems.
