throttle curve for JR 783?
Throttle curve for JR 783 radio?
What I need is throttle curve or something similar that will give small movements in travel for each click on the throttle stick, ie. hovering one minute and one click it's falling out, one click or 2 and it's climbing. For: "Airplane" thanks, Perry |
I'm sorry to say that the 783 does not have any multi-point mixes, so you would not be able to set up a curve mix.
Thanks Danny.
I suppose I need to use a smaller servo arm for the throttle to give a longer movement on the stick. Maybe it's time to get a new JR radio too. The 783 has been a good one for sure. best regards, Perry |
throttle
If you are talking about the the ratching on the throttle that locks the stick in place at a certain setting . On mine I turn the tension spring in side the radio on the throttle up side down so that it removes the ratchet feeling it makes and it lets it move smooth
at fractions of movements. |
