If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    Apr 2005
    buchanan, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    40% 330l pull pull
    Hey im setting up my 330l and it had 2 servos in the tail when I recieved it im installing a seiko on the rudder the tray is built im looking for information on a pull pull large enough and any suggestions for the exit of the cables. thanks for the help.
    Chris
  2. #2
    Kevin Y's Avatar
    Join Date
    Dec 2004
    Mooresville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 40% 330l pull pull
    Chris,
    I actually use 90 lb leader wire for pull pull available at any good fishing dept store. you should also be able to get the feurls need to lock them also. You probably want to use about a 4 inch arm on the servo. I actually cross the leads and make an exit between the two servo ( rudder)bays in the rear of the fuselage. You will have pleanty of torque with the Seiko but the centering on return can be a little issue if you fly percision.
    Al Young
    JTEC/RADIOWAVE
    www.jtecrc.com
    www.futaba-rc.com
    www.desertaircraft.com
    www.composite-creations.com
  3. #3
    Join Date
    Apr 2005
    buchanan, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    any tips on crimping the pull pull wire or do you guys have any issues with slipage.
  4. #4
    al's Avatar
    Join Date
    Sep 2003
    mooresville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Chris,
    What you want to do is feed your pull wire through you ferrel then through you linkage ( we use a 4-40 ball link with an sullivan 4-40 eylet attached to the control horn) back through the ferrel.
    Ok you want to make sure you have some extra wire because now you want to loop back over the ferrel and push the wire through the ferrel again from the linkage side all before you crimp. What that will do is lock the pull wire in so it can not slip.
    To crimp it I would go to lowes or a fishing supply house and get an inexpensive crimping tool. Then you will be set forever!!
    good Luck
    Al
    JTEC/RADIOWAVE
    FUTABA
  5. #5
    Join Date
    Oct 2003
    Great Mills, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Another trick if you use coated wire is after you are done running it through the eyelets, go back with a lighter and gently melt the coating together. I've done this on my pattern stuff for years and the stuff never moves.
    Arch
    Team JR, YS Engines, Morgan Fuels, F3A Unlimited, Team BJ Craft, Thunder Power RC, Castle Creations, Vogelsang Aeroscale
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
