construction manual
I recently acquired a 35% Panzl pak and it has the Extra 300 manual with it. It has "use as referance for Panzl" written across the cover page. Is this OK to use, or is there an updated version available? I'm anxious to get started. I'm back in the Charlotte area now, not too far from Mooresvile.
Thanks Z |
RE: construction manual
Basic difference are the formers for the fuselage. The bottom on the Panzl are flat and the extra have a radius. other than that they build the same. You should have a fuselage print for reference also.
If you have any question call us at 704-799-1658 Al |
