Info from Data Terminal after a shutdown
My Feedback: (15)
RE: Info from Data Terminal after a shutdown
Anytime you get that high pitch noise from the pump and overload error, The pump is froze. Sometimes taping on t with a srewdriver handle will unstick it. I think these pumps are a little sensative to this happening. I've had it happen myself.
Three flights today and three flameouts! All after 4-5 minutes of mixed flying. Fortunatley I'm damn good at deadstick landings. Bubble trap was at least 80% full. Was a hot day for UK standards. 30degs maybe. Last flameout happened on a nice half throttle fly by. Any advice appreciated.
Dominic, I have a few questions for you...
1) What's the serial number of your engine?
2) If you could replicate the flame out on the ground?
3) Is it at a certain RPM range from throttling up and/or down?
4) After flame out, press #1 button for message
Barry
Barry
Thanks Barry. Annoyingly I don't have the s/n and can't get to it without taking the turbine out of my Futura. I'll do some more testing and see if I can replicate the flameout on the ground.
Barry
If it helps this is one of the 2 k140's you supplied to me when I was a dealer in the UK.
I have one registered so the serial number will be the other one
My 140 is working fine in the F15. I know Dominic had issues with the pump. Was it replaced or just repaired?
Sorry I can't be more help Dominic as I don't sell KIngtech turbines in the UK now.
I'm sure Barry will sort you out.
Ian
Ian
#31
Hi Ian - Pump was repaired but returned without new plastic shielding which I wasn't too impressed by. I'll try to do a video'd test run tonite over 5-6 minutes and see if I get a flameout.
One thing I would like clarified. The very end of the turbine is well into the bell of the exhaust pipe. Is this OK?
Barry - Can you look up the serial number based on what Ian says above? Does it have any bearing on the problem?
#32
Just did a test run of 7 minutes. Full power for couple of minutes at a time a no problem.
Before start temp 24DegC. Idle RPM 34K. Max RPM 114.5K at 476DegC.
Sound OK? So frustrating when the same problem can't be replicated on the ground.
What would be different in the air?
#33
I didn't know it's a 140, which case serial number would not mattered at all. Sounds to me you have fuel plumbing issue, check clunk, vent.....etc.etc, but before we rule out turbine related issue, make sure your pump pw and EGT are all normal.
#35
Pump pw and EGT are accessible from the GSU are presume? Would have been good to know that before testing. Will try again at the weekend then.
#36
Did you say you had air in the uat Dominic? If so I would certainly look at the plumbing. Maybe air us getting in in flight which doesn't happen when running on the ground.
#37
ORIGINAL: DominicM
#38
ORIGINAL: ModellbauUK
#39
Just a thought. On my pumps the plastic shielding holds the pump to the motor. Worth checking that air isn't getting in there. Trying jiggling the pump when running the turbine as this may mimic movement in flight.
#40
New season and back to this model to see if the K140F will run properly. Basically a No based on today. First flight got a flameout and that's what it said on the GSU. Tried again on the ground and got same but noticed that I was getting 'Pump limited reached' before the flameout. Took the BVM UAT out of the system (fuel tank direct to pump). Started up again and got same result with 'Pump limit reached'. Took the fuel tank out of the system by taking fuel line out of the pump into my fuel jug. Same! Got 'pump limit reached'.
I've re-plumbed this complete system twice so it's not a blockage. I've sent the fuel pump back once, it was repaired and sent back. What else could be the problem? I'm thinking the fuel pump is still faulty. 2 years I've had this turbine and not got it to wrong properly yet. [:@]
#41
while it does sound like a pump it could also be a solenoid closing at high flow if plumbed in backward or anything between the pump and turbine, try disconnecting the tube from the turbine and test running the pump at various speeds and see if you see/hear a problem.
#42
ORIGINAL: KC36330
1) what is your pump limit currently set at?
2) on the ground, what's your pump pw at full RPM, if possible?
Sorry for your troubles,
Barry
#43
My Feedback: (57)
ORIGINAL: marquisvns
I concur with KC, sounds like solenoid not opening all the way and pump limit reached.
Barry
ORIGINAL: KC36330
Barry
#44
If there are two T fittings and a shutoff valve, then he could turn off bypass during start up, and after it is running turn the bypass on.
#45
Pump limit is 0428. I'll do another test to see if I can get 'pump pw at full RPM'.
Have done another test replicating the issue and video'd the GSU while running. Will post the vid soon as uploaded.
#46
Complete cycle from start up to the fault and then shutdown and cooling.
'Pump limit reached' happens at 4 minutes.
I don't have additional Ts or valve to create the bypass. I'm very doubtful its the solenoid as on the first flight I did get full throttle for a while before the flame-out. Still think I've got a duff pump.
Worth swapping the solenoids around?
http://www.youtube.com/watch?v=OAxl6rwEq6Y
#47
that's a turbine engine, not a harley at a red light, you don't rev the engine up and down like that, that video was useless IMO.
#48
ORIGINAL: KC36330
For a Kingtech Rep you certainly are eloquent with your advice.
#49
ORIGINAL: DominicM
Fine. Good to know. Thanks for your input. Didn't realise I was doing that to be honest. Lesson learnt.
ORIGINAL: KC36330
the video shows no fault of the turbine, it runs fine up till you start jamming the throttle stick up and down to induce a fault (the pump can't possibly keep up with your up/down/up/down demands), i'm sorry you needed that sugar coated.
#50
Oh I see now. It's my fault. OK. I'll do another test tomorrow and move the stick very gently and see if I get the same issue. Fairly sure I will.
But I'm just curious, you're inferring that moving the throttle too quickly will always cause this type of problem? I would have thought the ECU would control the acceleration of the engine regardless of how the user moves the stick.
