FOD screen attachment
CO
How do I solidly attach the FOD screen to my K140G? Ducting in my ultra flash won't hold it in place or keep it from slipping off the end of the starter.
thanks,
Jeremy
thanks,
Jeremy
If it's just the universal accessory type just run some silicon sealant
around where it buts up to the engine front cover.
Once dry it won't go anywhere & if you need to remove it just cut
through the silicone with a knife. - John.
Jeremy,
Another option is to buy a rubber o-ring at the hardware store that fits snugly around the starter. I put a drop of CA on each of the four bolts holding the starter on (the 0-ring touches them) and it was very secure.
Regards,
Gus
Regards,
Gus
