JETI dc-16 and kingtech engine
Hello guys anyone is using Jeti TX for kingtech turbine I'm wondering the trim mode should be on centered or linear ,thro-low,thr-L or thro-high also the rate should be on 100-100 or more .
Hye,
I use a Graupner MC-19 with a Jeti Duplex module with the Kingtech.
Mine is programmed as follows:
- throttle trim low engine out.
- throttle trim high engine is start up mode,
- throttle stick forward and back, starting.
- throttle stick at idle and trim to low is shut off.
travel 100-100.
Grt,
Berto.
travel 100-100.
Grt,
Berto.
Hye,
travel 100-100.
Grt,
Berto.
travel 100-100.
Grt,
Berto.
Hi Warblood.
Have you got your Jeti sorted out, I run a DS 16 on all of my turbines if you are still having trouble give me a call and I will run through the settings with you .
Cheers
Mav
Cheers
Mav
