engine not cooling !!
Hi,
I have noticed that if the engine runs out of fuel it will stop and shows "low rpm" message, I have no problems till here but the weird thing that the engine will not go to the cooling process even if I try to cool it manually from the throttle stick !
I have to quickly switch off the receiver and start it again and start the manual cooling from the radio.
any help?
also the second weird thing happens to me when I switch off the engine and after finishing the cooling process if I started again it shows "flame out" and nothing happens after that and I have to restart the receiver in order to initiate the startup.
my engine is K80G
ECU version 6.20i
any help?
my engine is K80G
ECU version 6.20i
yes i got this information recently !!
this engine is new member of my engine collection and all of them are Jetcat, and i used to restart the Jetcat engines after they get coolled without the need of restarting the receiver..
i have tested the engine cooling after initiating the low rpm message and trimming down the throttle and it went to the cooling process successfully.
but frankly speaking, what will happen if i forgot to trim down and not intering the engine to the cooling process?? this small mistake will cost me one pair of new bearing i think !!!
You can choose to cool down or not, depending on the situation. If your engine stops flying, and you donīt trim down the throttle, the engine will not cool down, that can be a good choice if you land out of the tarmac. and the inlets ingest dust or sand. I think that this is the reason for this feature of the fadec, all the Xicoy fadec works in this way.
Regards
Regards
Regards
Regards
