KingTech Service Center is expanding once again!!
Gentlemen & Ladies,
I am happy to announce that the KingTech Service Center is improving the shop once again. The construction should only take a week to 10 days. The down fall is I will not be able to fix anything while it is under construction. If you send a turbine in for service, please put a note in the box if you are willing to wait for my shop to be back to normal or if you want it send on to Taiwan to be fixed. There are no extra charges for it to be sent to Taiwan. The Factory is very fast at repairs and turn around time, so don't be discouraged about sending it to the factory.
Also, I have a NEW Service Center / Tech Support # 626-808-6122. The old # will be turned off shortly so make the change in your phone. I am also happy to help you out with any Sales needs.
Sorry for the inconvenience,
Dirk
KingTech Service & Sales
Dirk
Thanks for the Info. I recently sent a K100 in and saw that it went to Taiwan and was wondering why. I also had NO return phone call from Dirk when I left a message. Sounds like you folks are pretty busy.
