New ECU
My Feedback: (9)
You will need a xicoy telemetry adapter plugged into you JR telemetry system. I have never used JR but it looks straight forward.
http://www.xicoy.com/catalog/product...roducts_id=362
Hey Gunradd, I've got an Ultra Flash on the way that I plan to put a k140G2 in. I know it's been asked a hundred times, but is there a time-frame estimate on the telemetry availability for Jeti? Weeks, months, 2018? Thanks!
#33
When I was at the factory last week, they were building twenty four K-160Gs and at least half of those are ready to be shipped out this week, and the rest next week. I also did see our PO for your engine, so I would say it's safe to suggest that your engine is one of the 24. I have already reminded Vera to forward you a tracking number, when it becomes available.
Barry
#34
Hi Arron,
Barry
Barry
Sounds great Barry
#36
#37
Hi,
Does the new ECU support 2S LiPo? 8.4V from receiver plug
asking because
starter/kero/turbine batt is 3S LiFe 9,9 V
and model has 2S LiPo for servos/RX
so if now I need a third battery only for ecu... it is getting crowded inside
I tried option with 5V BEC but I get weird rpm numbers probably from EMI/RF noise
thanks
https://www.youtube.com/watch?v=QKBvLfgI44Y
asking because
thanks
#39
thanks,
but the question was about voltage from throttle channel.
can it be 2S LiPo?
I have it set up and running,
https://www.youtube.com/watch?v=cc2kfuvqnu4
but with :
1x 3S LiFe 9.9V battery for starter/glow/pump
1x 4S NiMh 5V batetry for RX input
and on plane I will have
1x 3S LiFe 9.9V for turbine
2x 2S LiPo for RX/servos
and do I need really an third battery like NiMh for ECU only?
or I can plug in rx channel (throttle) bringing in 2S 8.4V from rx/servo battery?
using an BEC to lower 2S voltage to 5V for it makes my ecu go wild, so that is not an option
video in my upper post
can it be 2S LiPo?
but with :
