KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
Urgent help!! K210 wont start
Old 10-29-2016, 08:34 AM
skymaster68
Default Urgent help!! K210 wont start
I have a problem starting my K210G...
I have an IGN fail msg...
this is the first time that that happens, I charged the battery to full charge also tried with another battery and it went to pre heat and nothing from there ...
Do you guys have any clues of what might be going on?? i'm at an event here.... it started fine 2 days ago...
Old 10-29-2016, 01:10 PM
gunradd
My Feedback: (9)
gunradd's Avatar
You can call Barry or Dirk on their Cell. Also sounds like the ignition fuel is a little low or in some cases its to high. Its a very easy adjustment. Did you change fuel types? What type are you using? Dial up the igntion fuel up a few clicks and try.
I will PM you my cell. I can try and help you also.
Old 10-29-2016, 01:38 PM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Did the OP reduce the voltage on the ECU battery that was freshly charged? If not, he may have cooked the glow plug.....
Old 10-29-2016, 01:42 PM
gunradd
My Feedback: (9)
gunradd's Avatar
If plug was bad it would say bad glow message. He's not getting temp rise at ignition. Could also be a bad temp probe....
Old 10-30-2016, 06:38 AM
skymaster68
Problem solved guys, thxs for your imputs, I called barry and increased the ignition pump pw a little and that was it...
As always Barry and the KT comutity was helpfull
