K170 Propane Start
My Feedback: (16)
K170 Propane Start
I purchased a new in the box (never run) gas start K170 from a fellow RCU Member. Manual says to use Coleman Powermax fuel to start the engine but, that fuel has been discontinued. Is it possible to start the engine using a Dreamworks Propane adapter attached to a Coleman "Green Can" of Propane? If so, are there any settings that need to be updated in order to use straight propane?
Thank you
Thank you
My Feedback: (9)
Thank you
Thank you
Yes the dreamworks adaptor will work. I have used it in the past. You will need to open it up all the way then push on the knob some to get enough propane to the engine but it works great.
