Battery for K310G
Battery for K310G
Good day, I'd like to ask for advice ... which battery I will use. I'm used to lipo and I work perfectly with other turbines I use. Thanks
My Feedback: (41)
I'm not clear from your post, but do not use a LiPo for the ECU on these engines. A two cell LiPo may not have enough power to get it started and then fly while a three cell LiPo will cook things in the engine like the glow plug. In fact, KingTech says you should not apply more than 10.0 volts and a three cell LiFe will come off the charger at about 10.6 volts. So a freshly charged battery needs to be drawn down to 10.0 volts before you initiate a start. The easiest way to do this is to just use the starter motor to spin the engine a bit which will pull the battery down 10 10.0 volts in a very short period of time.
