Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > KingTech Turbines International
Reload this Page >
2 new K180 G2 Pumps running when batteries installed but jet is off.
KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
Old 08-30-2019, 10:05 AM
dboyle
My Feedback: (58)
Default 2 new K180 G2 Pumps running when batteries installed but jet is off.
just installed the twins in a jet, pretty sure the wiring connections are correct ( but you never know)
as soon as I plug a Life battery into either turbine the pump goes on!!!!!
am I missing something?
done this setup several times with other brands, this is a first for me..
the radio is learned to the turbines ( no pump/ Life battery installed for setup)
anyone.. suggestions....
Old 08-30-2019, 12:11 PM
Dansy
My Feedback: (53)
Dansy's Avatar
Something is wrong in your setup for sure......not seeing anything’s I can’t help you more...
Old 08-30-2019, 07:10 PM
mauryr
With the original xicoy ecu, pumps could end up running uncontrollably if the ecu was damaged (I think a mosfet could fail closed after overheating).
Not sure about the kingtech ecu... odds are connections are incorrect though.
Johnny Isaiah Woods
My Feedback: (81)
Default fuel pump
With out any hesitation, your wiring is incorrect, your battery lead is going to the pump and pump lead is going to the battery ( ask me how do I know). Look at the ecu drawing (on side of ecu) ,
follow pump + red wire at ecu to pump + red wire, then pump - black wire at ecu to pump - black wire, do the same for the battery. You will find two wires have been switched. I hope this
will resolve your problem, it did mine.
Johnny
Old 08-31-2019, 04:21 PM
joeflyer
My Feedback: (48)
For the wiring harness that connects the pump to the ECU: make sure that the MPX connector with 4 wires is connected to the ECU and the one with 2 wires is connected to the pump. A friend had his reversed and it did exactly what you described.
By the way there's a note in your manual warning you about this.
